1LE alternative... may just work
Old Jul 11, 2003 | 06:22 PM
  #251
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Side view showing bracket thickness and caliper carrier clearance. 3/8" thick bracket, no modding to the carrler at all:
Old Jul 11, 2003 | 06:23 PM
  #252
ebmiller88's Avatar
I tried to get a close up shot of how well the rotor is centered:
Old Jul 11, 2003 | 06:30 PM
  #253
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Originally posted by ebmiller88
I don't know what the GM P/N you posted is for.
I don't either. Just that they're supposedly 3". Guess next time I buy parts I'll pick a few up.
Nice pics!
Old Jul 28, 2003 | 03:52 PM
  #254
ebmiller88's Avatar
No updates in a while from anyone, huh....
Anyhoo, I tear into the C4 upgrade on my '91 RS tomorrow. I still need to get the banjo bolts for the brake lines but that's about it. I'll be putting all the pics up again on my web page for all to see if interested. I may wait on some new strut mounts but I'll cover all the basics and stuff.
More to come!
Ed
Old Jul 28, 2003 | 03:59 PM
  #255
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Ed,
Please refresh my memory. Are you using C4 front, or rear rotors?
Old Jul 29, 2003 | 06:17 AM
  #256
fly89gta's Avatar
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
Well I'm doing the C4 brakes over the winter. A friend of mine did the swap with very good results. He can fab up the bracket for me as well. He used the C4 HD brakes, the ones found on the GS and ZR1's with the 13'' rims and they just barely fit under the 16'' times...just barely but they fit nonetheless
I can't wait...hell even all of the C4 stuff NEW from GM is still cheaper than what you find used 1LE stuff for
Old Jul 29, 2003 | 06:36 AM
  #257
ebmiller88's Avatar
C4 rear rotors, Dan. I will continue to work with the upgrade using the front rotors also, but the rear rotors may be the way to go.
Ed
Old Jul 29, 2003 | 10:57 AM
  #258
alloy's Avatar
Car: 87 IROC-Z28
Ed, I figured you were using the rear rotors because of the bracket thickness. But just wanted to check anyway in case I do a set for someone.
Old Aug 1, 2003 | 05:55 PM
  #259
ebmiller88's Avatar
Finished!
Ed
Old Aug 1, 2003 | 06:38 PM
  #260
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Out of curiosity, how $$$ and TIME do you guys have invested in this?
I just want to compare. I have approximately $1100 to $1200 into my front 1LE set-up but that inlcudes:
1) rebuilt PBR calipers from AZ
2) carriers and brackets from SSPE
3) Timken bearings and seals from AZ
4) Modified spindles from a fellow f-bud
5) slotted rotors from ebay
6) Earl's brake lines from Summit
7) EBC brake pads from Tire Rack
8) Caliper retaining pins from AZ
9) New GM master cylinder from Dal @ Vandevere Pontiac
10) New GM prop valve from GM Parts Direct
11) New banjo bolts from local dealership
12) All parts powder coated and/or yellow zinc plated
For kicks, here's a pic of some of my parts:
Old Aug 1, 2003 | 06:46 PM
  #261
ebmiller88's Avatar
Time: I was fortunate enough to do all my machine work myself but it took me about 12-13 hours for all: spindles (1 hr), machine the rotors into hubs (4 hrs), and make the brackets (8 hrs: I made 4 sets, one set from stainless). Spindles are the easiest, making the hubs takes a bit more time for the lathe to do the work, but since I did the brackets by hand, they were the most time consuming. I am looking into having them made, should I need to do so again.
$$$: My entire C4 setup now installed on the car ran me $252, plus or minus $10 for little things. See my new thread on the install, I gave a price breakdown. I also did the 1LE install on my Iroc and I came up with right around $800 for that system, and they're almost the same, except I have to repack bearings on the 1LE system when I replace rotors.
Ed
Old Aug 1, 2003 | 06:52 PM
  #262
alloy's Avatar
Car: 87 IROC-Z28
Well as I recall I had around $400 in my C4 setup with used wrecking yard parts. And like Ed I used the pads that came with the calipers since they were in such great shape. But I bought extra spindles and rotors to play around with, so that was an added expense.
I did the work myself on the rotors and brackets. I own a machine shop, and Ed had access to machine tools to do to do his work on, so this is the reason why we are in this so cheaply. Otherwise you would have to add around $200 for the modified rotors/hubs, and caliper brackets. I also already had the braided lines, so there was a $70 savings right there.
Old Aug 1, 2003 | 07:20 PM
  #263
MartinCadek's Avatar
looks awesome
I guess the LS1/C5 thread disappeared huh ?
could we possibly start another and just keep it decent so it wouldn't get deleted , this C4 mod is great but a lot of us has 17" wheels and bigger is better :-) it was a great thread that for some unknown reason got deleted
Old Aug 1, 2003 | 08:58 PM
  #264
ebmiller88's Avatar
You'd have to contact a mod to see what happened I guess...
Ed
Old Aug 1, 2003 | 11:03 PM
  #265
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
it wasnt deleted.... no one replied in it for awhile, so when the sticky was taken off, it flew back a few pages..
https://www.thirdgen.org/techbb2/sho...hreadid=183169
im going to attempt the LS1 brake swap..... mostly because if i have the LS1 fronts, and swap in a LS1 rear, i then can set everything like a stock LS1 setup... and later on when i have the money, i can get some eradispeed rotors..
then i have big brakes that look cool too...
i just started working at a machine shop, so i can finally cut my own parts.....
now i just need to figure out how im going to do this.....
Old Mar 8, 2005 | 09:52 AM
  #266
ebmiller88's Avatar
Anyone looking for this thread, here it is.
Ed
Old Mar 8, 2005 | 10:36 AM
  #267
IndyTruck's Avatar
Hey, when you rough-cut most of the rotor off to begin making a hub, would a plasma cutter be OK to use?
thanks!
kevin
Old Mar 8, 2005 | 01:29 PM
  #268
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I was planning on using a bandsaw to rough mine out before I finish the lathe work, I would not try a plasma cutter because it might make the cast iron VERY hard where its cut at and that would make it much harder to machine in the lathe, I've tried to machine some cast iron parts that had been welded on and anytime the carbide tool got close to a weld it would dull the insert.
Old Jun 2, 2005 | 10:37 AM
  #269
mars22's Avatar
Car: 83 firebird s/e w/ttops and a/c
Engine: 2.5 iron duke/ tech IV
Transmission: 5 speed
so does anyone have a pic and dimensions for the custom braket?
Old Jun 2, 2005 | 11:01 AM
  #270
ebmiller88's Avatar
Did you read this thread at all? It's on Page 2 about half way down the page...
Ed
Old Jun 2, 2005 | 11:54 AM
  #271
mars22's Avatar
so i would need ...
2 hubs machined from stock rotors redrilled and studded for c4
rotors
2 stock c4 calipers
2 custom brackets 1/4 inch wide
is that all?
Old Jun 2, 2005 | 12:05 PM
  #272
ebmiller88's Avatar
Not quite... here you go:
You won't have to redrill the rotors, they slide right on;
You'll need longer studs but they press into the stock bolt holes with no mods needed;
C4 brakes: Calipers, carriers, pads, guide pins, and longer brake lines;
3/8" brackets for standard 12" brakes, 1/2" brackets for HD 13" brakes;
bolts for the brackets and Metric bolts for the carriers;
modded spindles.
Ed
Old Jun 2, 2005 | 12:10 PM
  #273
mars22's Avatar
and this will all fit stock 15s?
Old Jun 2, 2005 | 08:53 PM
  #274
ebmiller88's Avatar
Yep, it should...."All" 15s does give you a wide range of wheels tho...
Ed
Old Jun 13, 2005 | 09:37 PM
  #275
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Also if you go with HD's you can use a 3/8 inch bracket and two 1/8 inch thick washers as spacers, that's the way I am doing it.
Old Jun 21, 2006 | 01:29 PM
  #276
Morit's Avatar
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
Can anybody send me CAD file for a c4 bracket?
bialooki@wp.pl
Old Jun 23, 2006 | 11:13 PM
  #277
ebmiller88's Avatar
I've got plenty of brackets but no CAD file, sorry.
Ed
Old Oct 26, 2006 | 06:16 PM
  #278
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
dose anyone have pics of the hub mods alloys pics are now red xs
Old Oct 10, 2008 | 10:07 AM
  #279
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Re: 1LE alternative... may just work
Can someone sticky this and perhaps prune some of the unneccessary posts out???
-jason
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
Fronzizzle
Aug 17, 2015 02:52 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
