Need clarification: Considering rear LS1 disc with 4th Gen rear. Potential problems?
Old Jul 7, 2003 | 10:52 PM
Arctic White 91 RS's Avatar
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
Need clarification: I'm considering swapping to rear LS1 type disc brakes from the current drums. I have a fresh 4th Gen rear from a 98 Camaro with 3.73's & Auburn posi I can swap in. Are there any potential problems with using the 4th Gen rear and LS1 rear disc brakes in a 91 RS?
I'm not aware of pitfalls with doing this based on the searchs I've done but I really have to know for sure before I spend a couple of hundred dollars on parts at Autozone.
Constructive comments & opinions are greatly appreciated.
Thanks in Advance.
Old Jul 8, 2003 | 11:29 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The only "real" problems I know of will be hooking up the emergency brake cables, you'll need to do some fab work to make up a bracket for the cables. It's been done so do a search for it. Other than that, maybe a pro valve swap but that's it...it's gonna work for ya.
Ed
Old Jul 8, 2003 | 11:34 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
and the wheel offset. the 4th gen rear is wider than a 3rdgen, so you wheels are going to stick out 2"
Old Jul 8, 2003 | 01:36 PM
Steve89GTA's Avatar
Get some y2k vette rims. Problem solved!!
Old Jul 8, 2003 | 01:39 PM
SLOWTBI's Avatar
i was thinking about doing this swap also, and i was wondering if anyone had pictures of their car with a 4th gen rear in it (either with the stock wheels or newer, 4th gen, ones) thanks guys
Old Jul 8, 2003 | 02:45 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
You know that their is a tech article explaiing how to do this and has answers to all your questions right?
Kat
Old Jul 8, 2003 | 11:22 PM
I read a tech article from this board on swapping LS1 brakes onto a 3rd Gen with drum brakes with a 3rd Gen rear. Is that the article your refering too?
I hoped I might turn up a little more info on using a adjustible valve to dial the line pressure in for the rear brakes. Looks like it will be a trial and error thing.
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Jan 19, 2016 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
