What is the latest on LS1 brakes?
Old Aug 30, 2003 | 12:25 PM
z28cdoyle's Avatar
Car: 85 IROC
Engine: 355
Transmission: Tremec 5 speed
I have been watching posts about the swap to LS1 front brakes on a thirdgen. When last I heard several guys were working on developing the bracket to mount the caliper to the third gen steering nuckle. What is going on with that bracket? Does anyone have one designed yet? A drawing with dimensions would be really nice.
I will be doing this swap on my '85 IROC over the winter and I'm "chipping away" at buying the necessary parts when I find good deals. If someone has designed a mounting bracket, that would help those of us following in your foot steps.
Old Aug 31, 2003 | 06:30 AM
PF Flyer's Avatar
Car: 87 T/A
Engine: TPI 350 ci
Transmission: 5 speed
... I guess a lot of folks are away for the holiday weekend.
TTT
Old Sep 4, 2003 | 04:59 PM
SDCal7's Avatar
LS1 Brakes
I was wondering the same thing. It's been a while since this thread started. I've come to the conclusion that I may have to get a spindle and hub (after modification) and do a mock-up and then design the caliper plate myself. With trial and error, it can be done.
Old Sep 5, 2003 | 04:33 PM
ZFORCE's Avatar
Car: '87 IROC
Transmission: TH700R4
Not sure if the bracket is the same but I think this guy sells them for the C5 brake upgrade.
C5
tj
Old Sep 5, 2003 | 08:32 PM
SDCal7's Avatar
A C5 caliper bracket may work if the rotors are the same size, 12", for the LS1 Camaro, but even if the difference is say, 12 1/2", the bracket design is a great starting point.
I believe the calipers for the LS1 Camaro are the same as the standard C5 calipers. There may be a slightly different rotor thickness which would require a different corresponding thickness caliper plate. I'll certainly find out. Send me the contact info for the guy with the C5 plates.
Thanks!
Old Sep 5, 2003 | 11:07 PM
z28cdoyle's Avatar
Car: 85 IROC
Engine: 355
I do not think the C5 caliper bracket will work for the LS1 brake swap. I understand the C5 and LS1 calipers are very similar but the rotors are different. LS1 rotors are 12" diameter where the C5 rotors are 12.75" diameter. I think this will be too much of a difference. Of course SDcal7 has a point that the C5 or even C4 bracket design would get us closer than if we had nothing. I plan to do the same as you guys, keep watching the board and fab my own bracket if nobody else does it first.
By the way, I found a good deal on used LS1 calipers at one of the local salvage yards. I got the left and right calipers (still attached to the caliper carrier), banjo bolts, and useable brake pads that were in the calipers all for $30.
I was concerned about uneven and tapered brake pad wear since the LS1 caliper is a "sliding" type caliper like the 3rd gen caliper. After I checked out the LS1 calipers in my garage, I realized all calipers are not the same. The LS1 are a far superior design than the stock 3rd gen pieces.
Old Sep 6, 2003 | 09:05 AM
SDCal7's Avatar
You're right about the differing rotor size, but from reading the whole thread on the LS1 brake swap, it appears that the calipers are the same which would at least provide a basic starting point for our purposes.
That's great if you happen to figure out the plate before anyone else. Yes, please post it. I'm just starting to paint my calipers and head to a salvage yard to look for a Camaro spindle so I can start the mock-up and design the plate. Let me know of your progress.
Bruce
Old Sep 14, 2003 | 09:16 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
I just got me a set of LS1 front brakes from ebay for 150.00. All I need is this caliper bracket that everybody is talking about making or getting the dimensions for to complete the installation. Has anybody made one yet?
Old Sep 15, 2003 | 09:38 AM
pwdbychevy's Avatar
ttt
Old Sep 17, 2003 | 01:04 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the basic caliper mounting design has been posted... i can be found here:
https://www.thirdgen.org/techbb2/sho...&goto=lastpost
Old Sep 17, 2003 | 01:26 PM
pwdbychevy's Avatar
Good stuff, Thanks!
Old Sep 25, 2003 | 10:11 PM
z28cdoyle's Avatar
Car: 85 IROC
Engine: 355
Many thanks MrDude.
I know all about the need for new engines. I started off replacing a blown head gasket last year. Six months and a few thousand dollars later I finally had the new engine (and many other stuff) finished.
1MeanZ
Dec 18, 2015 05:39 AM
dbrochard
Sep 19, 2015 08:13 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
