13" C4 HDs Installed...who needs Baer??
Old Apr 5, 2009 | 01:08 PM
  #101
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: 13" C4 HDs Installed...who needs Baer??
Originally Posted by 1987CamaroZ28
Ed,
Do you have the backing plates needed to install the PBR calipers on my '87 9 bolt that came with the iron calipers?
If using the same calipers just redrill the backing plates for your 9 bolt.
Ed
Old Apr 5, 2009 | 01:09 PM
  #102
ebmiller88's Avatar
Originally Posted by bigals87z28
Are there any other brake upgrades I must do? Prop valve?
No, stock master and prop valve is fine with front upgrades.
Ed
Old Apr 5, 2009 | 01:44 PM
  #103
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Hey Ed,
Any updates on the LS1 front brakes package? Sent you a pm not too long ago..
Old Apr 6, 2009 | 09:37 PM
  #104
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Ed, don't take this the wrong way, but the reason some us use Baer is because we want something more than a 2 piston PBR caliper. There are very few people out there who make a brake that has something bigger than a 2 piston PBR caliper and Baer just happens to be the most popular.
If I were stuck choosing between 2 types of 2 piston PBR setups, I'd buy yours no questions asked. But Baer does offer a 6 piston PBR caliper that will fit 13" rotors under most 17" wheels out there.
Old Apr 7, 2009 | 09:37 AM
  #105
Doesn't Ed's 13" 2 piston setup fit under 16 inch stockers? I think that's a big advantage not having to go out and spend a bunch of $$$ on wheels just to fit bigger brakes.
Old Apr 7, 2009 | 10:40 AM
  #106
ebmiller88's Avatar
No offense taken. Baer offers great stuff but at a budget that some guys don't have access to. Have you looked into a Wilwood SL6 or GN 3 caliper? Both are 6 piston and work well. The GN3 pads are HUGE! I did a SL6 kit with a two piece 13" x 1.25" rotor that fit a stock 16" Z28 wheel, very similar to the 12.2" setup some guys run.
Ed
Old Apr 7, 2009 | 10:41 AM
  #107
ebmiller88's Avatar
Yes, HDs fit stock 16" wheels.
Ed
Old Apr 8, 2009 | 11:05 AM
  #108
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
Well, my car came with 15x6's stock, so 17x8 wheels and tires will be a nice upgrade for me.
Ed
No, I hadn't seen those Wilwoods. Will have to look into that for sure. Might be giving you a call when I get around to doing my brakes
