Need help with Drum Brake Parts
Old Oct 20, 2004 | 02:20 PM
Magician's Avatar
Car: 1989 Camaro
Engine: 2.8L V6
I have a 89 Camaro. I have Drum Brakes on the rear and I was thinking about replacing all of the parts on the drum brakes with new ones.
I don't have the money right now to replace the rear end to disc brakes so I thought I would just redo the drum brakes I have.
Does anyone know where I can get drum brake kit from? If not, can anyone list all of the parts I would need to replace the hardware in the drums? I appreciate it
Old Oct 20, 2004 | 02:43 PM
-ZERO-'s Avatar
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
Best thing to do is go to your local parts store and let them know that you need new break shoes. And if the drums that you have on there right now can not be turned, then go ahead and get new ones. I dont think there that expensive. and get you some break parts cleaner. hopefully you wont need to replace the little break cylinders ( i forget what they call them ) that are in there. have fun!!
Old Oct 20, 2004 | 02:57 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
you can also ask for the hardware kit, it has all the spings and stuff you need for the change.
Jeff
Old Oct 20, 2004 | 04:43 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Wheel cylinders on the rear drums are what they are called. If you do new cylinders, turn drums, hardware, and pads, it should run between $80 - 100.
Old Oct 21, 2004 | 07:55 AM
-ZERO-'s Avatar
Engine: 305 H.O.
I was close!
Old Oct 21, 2004 | 08:20 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Does anyone know where to get aluminum drums? Or mabee what year cars they came on?
Old Oct 21, 2004 | 08:50 AM
-ZERO-'s Avatar
Engine: 305 H.O.
From what i've heard you can not buy them new anymore. And as far as the years that they came on.... :shrug:
Old Oct 21, 2004 | 11:54 AM
wilyk9's Avatar
Car: 85 Trans Am
Engine: 305 Carb
My '85 TA had the big finned aluminum drums when I removed them to install the discs. Not sure if they are still available though.
Old Oct 22, 2004 | 01:15 AM
USA_Rally's Avatar
Car: 92 Rally
I just did a my rear brakes last weekend and I got all my parts from Napa. Assuming your cylinders aren't leaking (like mine were) all you will need is a pair of shoes and a spring kit (which Napa has). I had to replace both cylinders, shoes, and springs and I did it all for under $50. I wouldn't advise having the drums turned unless they are in real bad shape. If your wheel cylinders are leaking let me know and I can tell you how to replace those, getting them off and on is real tricky. If your gonna tackle this with out having done them before I would advise buying a Haynes Manual for $15, I don't think I could have done mine successfully without it.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
