Brake Conversion?
Old Oct 21, 2004 | 07:46 PM
Magician's Avatar
Car: 1989 Camaro
Engine: 2.8L V6
Brake Conversion?
If I change my rear drums to disc brakes, is it as simple as just changing them to disc brakes or is there alot of new hardware and adjustments needed and involved?
Old Oct 21, 2004 | 08:12 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The topic has been covered many times. You might consider a search for more thorough info. Off the top of my head: modify the axel flanges, master cylinder (I think) and proportioning valve, brake hardware, e-brake cable.
JamesC
Old Oct 21, 2004 | 08:17 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Here's what you're in for. This is for LS1 rear discs:
https://www.thirdgen.org/newdesign/t...reardisc.shtml
Ed
Old Oct 21, 2004 | 10:22 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
baer brakes also make a complete kit for rear conversion its like 800.00. all parts needed are included everything bolts right up. the brakes are then pbr 4th gen style, if you have lca relocation brackets they need to be moded to fit the e barke cable brackets. this is a box kit if you like that kind of stuff.
ebmiller has great info on other options if you like to save some money and find parts and put all together yourself. i belive his is less money but not 100% sure. i did the pbr from bear with no problmes.
Jeff
LittleFranks
Oct 7, 2015 11:26 PM
dbrochard
Sep 19, 2015 08:13 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
