Need help with brake upgrade
Old Dec 7, 2004 | 11:21 AM
DDiggler's Avatar
Car: 1984 Camaro Z-28
Engine: 305 H.O.
Transmission: 700-R4
I was looking to redo my brakes and was wondering what I can do to upgrade my brakes. I currently just the stock rear drum brakes?
Old Dec 7, 2004 | 11:30 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
when i was looking to upgrade mine i found, a 88 posi rear with disk that i swaped in. it came with all the disk parts for rear disk. i did eventully change to baer brakes but it made it easier to do the swap.
alot depends on what you want to spend. Baer makes a pbr upgrade for the rear that comes with all brackets pbr is like a 4th gen rear brake set up i believe. it is a 12' rotor and will fit under a 15 stocker.
there are alot of other choices too.
jeff
Billy Decker
Sep 4, 2015 03:46 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
rudolphschenker
Sep 4, 2015 02:41 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
