Rear disc problem
Old Dec 12, 2004 | 07:56 PM
DarkKnight33's Avatar
Car: '88 Pontiac T/A GTA
Engine: 5.7l/350 TPI
Rear disc problem
I'm having an issue putting new pads on my rear discs. I know I'm missing something simple, but no matter how hard I try to drive the caliper piston back into the bore it won't go. I bent a brand new craftsman 6" C-clamp trying to do this. I even tried opening up the bleeder valve to release the pressure just incase the fluid wouldn't return into the master cylinder for some reason. That didn't help either. I think it might have something to do with the e-brake, but I have only worked on front disc - rear drum before so I can't be sure. The damned haynes manual is no help either. So if anyone could venture a guess as to what I'm doing wrong, I'd appreciate the help.
Old Dec 12, 2004 | 08:03 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You have to screw the pistons back in, not press them.
Old Dec 12, 2004 | 08:40 PM
Just twist it? I've never heard of that before. Is it possible I damaged it by trying it press it back in?
Old Dec 12, 2004 | 09:30 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
It's probably stuck, those calipers are known for that. Rebuild them while you're at it with the recall kit and that will fix your problem.
Ed
Old Feb 18, 2005 | 09:17 PM
maroguy1's Avatar
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
Do you know what the rebuild kit part number is from gm??
Old Feb 18, 2005 | 10:41 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's the way most rear caliper setups with parking brakes work. It's possible you could have stripped the threads with the clamp.
Old Feb 19, 2005 | 11:24 PM
Lol, that was months ago. No, I didn't strip it. I just gave it a little elbow grease and it started rotating right back into place. BTW, EB thanks for the advice.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
