stock 15" wheels what rear disc fit?
Old Jan 13, 2005 | 08:03 AM
89rsragtop's Avatar
Car: blue
Transmission: 6 speed
Axle/Gears: 3.73 posi
I would like to change my 10 bolt from drum to disc. I also want to keep my stock 15" rims for the sleeper effect they have. What will fit? Does anyone make a kit ?and is it worth it?
Old Jan 13, 2005 | 03:51 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
the stock rear disk should fit under 15's after all the rotor is only like 10" I think
Old Jan 15, 2005 | 06:54 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
What year is your rearend, and is it a 3rd or 4th gen rear?
Ed
Old Jan 15, 2005 | 08:18 PM
89rsragtop's Avatar
Car: blue
I have a 3rd gen 10 bolt drum rear. What I really want to know is what is the best setup that will fit under the wheels. I have also heard that some rear discs brakes were not good. I think the cast iron calipers were problem prone?
Old Jan 17, 2005 | 06:49 AM
ebmiller88's Avatar
Right...stay away from the iron calipers unless you install the recall kit in them. The 12" LT1/1LE PBR rear brakes are what you want and they should fit the stock 15" wheels just fine, although they may not fit your spare depending on which spare you have. I'd go with the brakes I described over the LS1 rear brakes. It will be an easier bolt on install than the LS1s will be.
Ed
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
kah992
Aug 19, 2015 02:55 PM
mustangman65_79
Aug 9, 2015 03:00 AM
