what are the benefits of 1LE master cylinder?
Car: 1986 Trans Am
ok I was able to complete my C5 swap just before the server went down. I have the disc/disc master cylinder should I switch to the 1LE master. If so what are the improvements over the other master I know the piston size is different. Any performance gains. I now have C5's in from and PBR's in the rear.
I can already lock up the fronts with the master I have. Would adding an ABS system from say a 92 be a better upgrade at this time?
hmm pic won't post for some reason
