What size spacers with C5 Z06 Brakes?
Old Feb 24, 2005 | 11:00 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
I just bought some 17x9.5 Z06 wheels.....have a 4th gen rear so that back is taken care of...on the front...I have some C5 Z06 brakes waiting to be put on. I believe I read somewhere that the Z06 brake upgrade will move the wheels out a bit...anyone know exactly how much? In addition, the hubs I had made are using the 1LE rotors...so thats even more that they will be sticking out. So, does anyone know what size spacers I'll need?
I did a search and this is the only info I found
difference between regular front brake hub and 1LE brake hub
~ .317-.318"
Standard Non-1LE front -small bearings(10.5" rotor)
3.630"
1LE brake setup- large bearings (12" rotor)
*THIS IS THE FACTORY STANDARD FOR 245/50-16 tires on an 8"wide rim*
3.948" [+.318 offset, or just over 5/16"]
My setup-large bearings (12.9" rotor) with a 3/16" wheel spacer for rim to caliper clearence
3.967" [+ .337" offset, or just over 5/16"}
13" C4 HD's on 1LE hub-large bearings(13" rotor)
4.248" [+.618" offset, or just shy of 5/8"]
13" C4 HD's on std hub-small bearings(13"rotor)
3.930" [+.300" offset, or just shy of 5/16"]
C5 setup on stand or 1LE hubs (12.75" rotor)
No clue?If anyone has a "+ or - "offset from any of the combo's above- please contribute."]
Old Feb 25, 2005 | 09:48 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
C5 rotor will add .300" and the 1LE hub will add .318", for a total of .618" (about 9/16"). So, I know a lot of guys will run either a 2" or 2.25" spacer up front with 4th gen or C5 wheels. Doing math, seems like you'll need a 1.382"-1.632" spacer so we'll say 1.5". I'd go no larger than 1.75" and you should be fine.
Ed
Old Feb 25, 2005 | 10:33 AM
mult68's Avatar
Engine: 305 TBI
Thanks a lot ed.....now in your opinion.....should i get a 1.4" bolt on spacer and fine tune it with some slip on spacers.....or get a 1.5"+ bolt on spacer and hope I like the results? Can they even make the spacers that precise?
I want to get these wheels tucked in as much as possible with no rubbing. Thanks
Old Feb 25, 2005 | 10:39 AM
ebmiller88's Avatar
You can barely see a tenth of and inch so just go with a 1.5" and be done with it. No need to be that precise.
Ed
Old Feb 25, 2005 | 10:42 AM
mult68's Avatar
Engine: 305 TBI
sounds good thanks
Old Feb 27, 2005 | 09:34 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Great I hope my C4HD brakes won't kick my tires out past my fender in the front. I'm using a 2" spacer for my 4th gen rims and I was planning on the same spacer for my 17x8.5 vette rims. Oh well, I guess I can take them to my old high school and turn them down a bit on a lathe.
Old Feb 28, 2005 | 09:26 AM
ebmiller88's Avatar
Lock has my LS1 front brakes with a 2.25" spacer with no issues. If you do the math it works out about the same so you should be fine.
Ed
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
jrdturbo
Mar 31, 2016 02:58 PM
Nervous2
Oct 8, 2015 10:53 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
