my brake pads lasted me 8,000 miles
Old Feb 27, 2005 | 03:37 AM
porkyzilla's Avatar
Car: 89 iroc-z 5.7tpi 350,
Engine: 5.7tpi 350,
how is this possible...they are the rayebestos brute stop pads, with the brute stop rotors cross drilled/power slotted,
it looks uneven wear though.....one side of the pad is more worn than the other, also the inside pads are more worn than outside... is this normal
Old Feb 27, 2005 | 04:21 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
The titanium guide pins that the calipers "float" on back and forth either needs to be greased or are worn and needs to be replaced and the new ones greased for a smooth hangup free operation. Its very common that the caliper will not glide smoothly on the pins and the pad on the piston side of the caliper will take the blunt of the pressure and constant contact upon release thus making it wear faster.
Even when everything is new and working perfect, the inside pad will always "slightly" wear quicker on a floating caliper system. But not in 8,000 miles. Should be at least twice that.
Old Mar 4, 2005 | 03:24 AM
redimpss5's Avatar
Car: 85 z28
Engine: 94 lt1
Plus, raybestos is not the best item to buy!
Old Mar 4, 2005 | 03:31 AM
porkyzilla's Avatar
Engine: 5.7tpi 350,
well your right i found 2 problems
no rattle clips were installed on the pads, and the pins were not greased.... thanks for the tip learn something new every day
Old Mar 28, 2005 | 12:19 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Where do you grease the pins?
Old Mar 28, 2005 | 02:05 PM
Verviticas's Avatar
Engine: L98 5.7
put the pin in the caliper while its only hanging from the car (not hanging of course, that coule kill your lines, i mean you holding it in your hands) you;ll see where the pins contact the calipers, grease it so it will slide along freely...kinda hard to explain. Just grease the whole pin.
Old Mar 29, 2005 | 07:35 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Don't forget to grease the sleeves. On the calipers inner mounting ears there is a sleeve and O-ring (two per caliper). The O-ring is in the caliper ear and the sleeve goes into the O-ring. These need to be greased.
The sleeves slide within the O-ring to float the caliper. Only the outer end of the pin slides within the caliper.
RBob.
Vintageracer
Jan 10, 2020 05:33 PM
Eric-86sc
Apr 3, 2016 03:52 PM
kyleb24
Aug 15, 2015 08:24 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
