one quick ? about drum to disc
Old Mar 26, 2005 | 09:07 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
hey guys i already have all the info i need but they told me someting today that cuaght mt atention.the shop that will be doing my ring & pinion swap told me that disc rear have bigger axles then drum,and that i will need to get the right axles for my swap?is this correct or can i use the axles on the drum rear i have?
Old Mar 27, 2005 | 01:04 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
If this is on a 3rd gen 10 bolt, the flange on drum axles where the studs are sometimes needs to be turned down a tad to fit the discs on. Any machine shop can do it for a nominal fee if need be. You dont need bigger axles for disc!!
Old Mar 27, 2005 | 02:42 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
the only thing i know i have to do is cut the drum flange and drill 4 holes to bolt on the back plate for the disc brakes.so the axlex are the same
Old Mar 27, 2005 | 10:13 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Turning axles can be both a PITA and costly. Just buy rear rotors for a '93-97 LT1 car and they'll slide right on.
Ed
Old Mar 28, 2005 | 08:29 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
my brake swap is going to be from an 87 iroc.i have new rotors/calipers/pads/lines.so why will i get lt1 brakes?
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
jrdturbo
Mar 31, 2016 02:58 PM
Numbah-1
Sep 20, 2015 09:31 AM
Prodigious
Sep 18, 2015 05:23 AM
Prodigious
Sep 18, 2015 05:18 AM
