is it possible to do a C5 brake upgrade for about $250
Old Apr 2, 2005 | 07:31 PM
BOTTLEDZ28's Avatar
Transmission: A4
Im looking for something to do on the car in the next few months and the C5 brake upgrade loks like something fun. Can I do this swap for about $250? I throw that figure out because I can have the brackets made for free, and I can also have my stock rotors milled down to create the new hub. I will do the spindle mod myslef too. So basically all I need to do it find a pair or C5 calipers and rotors right? I know about the hardware that is needed as well? Am I missing anything else here? I have all the tools needed as well and I WILL do the spindle mod with them on the car. I also have a 4th gen LT1 rear with the stock setup so I amy upgrade those is its worth later in the futher. So, you think I can do this for thatprice or should I use the abundent LS1 brakes? I really only use the car to ride around town and stuff.
Old Apr 2, 2005 | 07:45 PM
BOTTLEDZ28's Avatar
Transmission: A4
edit,,,,,, I just did a little more research and now I know that the "LS1" and C5 brakes are pretty much the same.............right?
with thar said, it means I can go to a local boneyeard and pull off the front calipers and rotors from ANY 98+ Fbody and start doing the swap. Is the red paint and the word corvette the only difference in calipers?
Old Apr 2, 2005 | 08:18 PM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
with ls1 brakes they are only 12 and with the vette they are like 12.7 . I think i did mine for like 580 with all new parts . The brackets were free and the hubs cost 45 , the studs cost like 30 since i got arp , you need pads , and rotors , calipers, the abutment that holds the caliper, you could deffy do it cheaper if you could get used stuff or if you got stuff from the bone yard , but i dont think you will find a c5 vette in the junkyard, but you have to decide what you want , the 12 or 13 inch brakes.
Old Apr 2, 2005 | 08:37 PM
BOTTLEDZ28's Avatar
Transmission: A4
well the price would be a LOT more if I went up one 1 inch and I dont think it owuld be worth it performance wise fo rme since the car doesnt see any hard road racing or anything. if I found a 98+ car in the boneyard, the I would really have everything there I need as far as hardware right. all I would need to buy outright is studs and pads(if the ads are bad on the car)
when you say"the hubs cost $45" do you mean it cost you $45 to have your machined? And this abutment that you refer too should be on the donor car if all the partsd are still intact right?
is this a complete list
2 calipers(LS1)
2 rotors(LS1)
2 rotors (mine) need to be modified
2 spindels(mine) need to be modified
brake pads set for LS1
2 abutments brackets
2 "special adatper brackets"
10 new longer wheel studs(how long if Iam already using wheel spacers?)
any hardware needed(should be whats on donor car)
is this everything
Old Apr 3, 2005 | 08:25 AM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
yeah it cost me 45 to have them machined, also a word of advise , i got the arp studs and they only come in one length , they say they fit but i managed to crack the hib when we put one in , so what we did to all the toher holes is use a .500 reamer and it just cleaned up the holes and made it perfect . You also need the little pins that abutment slids on .
ok here is a list of everything i needed to do the vette mods, i have parts numbers but htey will be differnt , but just to guve you the " idear"
front lh rotor
front rh rotor
ceramic pads
caliper lh
caliper rh
abutment need one from each side
boot kit need 4 , these cover the pins so dirt doesnt get in
slide pin need 4
banjo bolt need 2
caliper to abutment bolt need 4
bolt , bracket to spindle need 4
Old Apr 3, 2005 | 10:51 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
If you can do everything yourself You can keep it on a good budget. Depending where you find calipers and Rotors.
I picked up some crossdrilled/sloted rotors form Summit on sale. Did my own hubs and brackets and will just buy calipers new from gmparts direct
I get studs dirt cheap at business cost so thats a saver right there also...
If you cant get something done yourself let me know.
There are quite a few people on this board who could help you get/make what you need.
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
Night rider327
Sep 2, 2015 04:18 AM
