Help with ss braided front lines !!!
Old Apr 18, 2005 | 11:26 AM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
How does the line come off at this point on the strut . does the clip pull off or do you undo the thin nut and it comes apart?
Old Apr 18, 2005 | 11:27 AM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
1st closeup
Old Apr 18, 2005 | 11:28 AM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
last closeup
Old Apr 18, 2005 | 11:31 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you pull the clip.
dont twist the nut.
Old Apr 18, 2005 | 02:12 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Pull clip with needle nose pliers. There's two types of clips. On ejust pulls right out, the other is U shaped and the top part of it slides over the fitting on the line. You must pry up on the top part of the clip (using a screwdriver works well) and at the same time pull out on it with pliers.
Ed
PS: Yours is the "just pull the thing" type so it just comes right out.
Old Apr 18, 2005 | 03:56 PM
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
thanks for the fast replies, i got it all done , ss lines are now on and the rotors hubs are painted . Thanks guys.
p.s. thanks for the lines you sold me like 6 months ago ed, they worked good.
Old Apr 18, 2005 | 04:54 PM
ebmiller88's Avatar
Glad to help...
Ed
Frozer!!!
Jan 19, 2024 04:55 PM
anesthes
42
Oct 24, 2015 07:30 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
