rear disc swap
Old Apr 21, 2005 | 08:57 AM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
Transmission: 700R4 Overdrive
rear disc swap
is it possible to do a complete setup my drum rearend with a 86 to 92 disc break setup rearend with little or no modification?
Old Apr 21, 2005 | 11:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
You'll have to modifiy the axel flanges on the drum rear. Afterward the swap is straightforward. Check the following link:
https://www.thirdgen.org/techbb2/sho...hreadid=249098
JamesC
Old Apr 21, 2005 | 01:10 PM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
brakes
no i meant to find a complete disc brake rear end to swap what is envolved in the process
Old Apr 21, 2005 | 01:27 PM
JamesC's Avatar
Simply drop one rear end and insert the other. You may need another master cylinder and/or proportioning valve. If you find a donor car, take these as well as the rear end, to include the e-brake cables if possible. For a step-by-step, you might consider a manual--or do a search here and you'll no doubt find something.
JamesC
Old May 4, 2005 | 11:47 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
JamesC....ok im sort of confused, i know once i get all the parts i need i can figure it out but what are ALL the parts i would need to convert from drum to disc (just the rear brakes)???
and yes the rear end swap is very simple, unbolt the driveshaft and suspension, remove brake lines and bolt the new one up. you may need new brake lines and i would defenitly recommend a new prop. valve since the way it is now the rear will probably lock up way before the fronts
Old May 4, 2005 | 01:36 PM
JamesC's Avatar
The easiest way is to simply swap in the appropriate disc brake rear end (choice of gears and posi). Take the e-brake cables, M/C and proportioning valve and you have what you need.
Drum to disc will require modification of the axel flanges. Check the following link:
https://www.thirdgen.org/newdesign/t...reardisc.shtml
JamesC
Old May 4, 2005 | 08:36 PM
dual_88s's Avatar
From: In my own little world - but they know me well in here
Car: 88 Sport convertible
Engine: 305TBI
Transmission: AUTO
Axle/Gears: 3.42 rear end
First hand experience....
My car has been down for 10 days doing just this very thing. I took a 91 rear end with J65 brakes and put it under my 88 with drum brakes.
DO NOT BELIEVE that all you have to do is reconnect the lines.
The hardlines will NOT attach to your calipers. You need the flexible brake lines with the banjo valve and crush rings. . Plus you will need new hardlines (shorter than with drums). And the bracket that holds them together. Also, new cables for your Ebrake. (Got them from Chevy for $24 each)
Yes the correct proportioning valve is important.
EbMiller88 says he has all the necessary parts. I am waiting on the preformed hardlines from him to complete my install. Got the flex lines, banjo valve and crush rings from Chevy. The brackets from Classsic Industries.
After getting into this, it makes me wonder how many of the folks that say it is "just bolt it in and reconnect the lines" have ACTUALLY done this.
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I'll chime in. All the parts to convert to PBR discs (I wouldn't waste time converting to iron calipers from drums):
disc backing plates, rotors, calipers, pads, correct e-brake cables, new or modified hard axle lines, 3 pc flex lines for disc rears, backing plate to carrier bolts, caliper banjo bolts for PBR disc calipers, crush washers, and about 3 hours.
Ed
Old May 4, 2005 | 08:40 PM
dual_88s's Avatar
Engine: 305TBI
Transmission: AUTO
What he said.....and he is supposed to have what you need and/or able to get them.....
Old May 5, 2005 | 06:04 AM
JamesC's Avatar
Many part numbers and pics for the PBR swap are in the first link.
JamesC
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
