Brakes Still Mushy
Old Apr 29, 2005 | 08:40 PM
redrummer's Avatar
Car: '88 Trans Am GTA
Engine: 5.7L L98
Axle/Gears: 3.27 Aussie 9 Bolt
Brakes Still Mushy
I've been working on these brakes for weeks now.
1) Replaced the master cylinder, bench bled according to instructions, no air whatsoever coming through the tubing when I was done.
2) Replaced brake booster, old master cylinder was leaking back into it. The pedal wouldn't firm up with the engine off.
3) Completely flushed entire system. Old fluid looked like coffee.
I bled the system down again last night. With the car off, the pedal stays nice and firm if I tap it and very slowly goes to the floor if I stand on it, like it's supposed to. I thought the problem was solved...until I started the car.
The pedal's going at least halfway to the floor before it feels like there's enough pressure to stop the car. It's definitely better than before, but it just doesn't feel right.
Tomorrow I'm going to run a new vacuum hose from the plenum to the booster, invest in a Mity-Vac bleeding kit, and probably put new pads all around.
Can anyone think of any reason my brakes are doing this? The absolute only things I haven't replaced are the rubber lines, the calipers, and the proportioning valve
Old Apr 29, 2005 | 09:18 PM
zdrag28's Avatar
Car: 85 z28
Engine: 327
Transmission: th350
Axle/Gears: ford 9in 4:56 to 1
sounds like air still in the system
how are you bleeding the calipers?
Old Apr 30, 2005 | 06:39 AM
redrummer's Avatar
Engine: 5.7L L98
The old fashioned way. Girlfriend works the pedal while I crack the screw.
Old Apr 30, 2005 | 11:30 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
id say the replace the hoses, im waiting on mine from hawks. i figure id work my way from the simple to the hard. I to suffer mushiness . replaced calipers and pads, shoes are alright but im getting to that .
Old May 1, 2005 | 01:33 AM
91blkta's Avatar
Car: 1991 Pontiac ta 5.0l 2005 pontiac gxp 5.3l ls4 dod 2003 GMC Envoy 4.2l
When I did mine recently somebody suggested to tap the caliper while bleeding air likes to stick to the sides. Mc can be a pita you may still have some air in there. I would recheck everything again If you have high miles or just a old car replace the flex lines they tend to flex if realy old which and give you a softer pedal.
Old May 12, 2005 | 03:54 AM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Mine are mushy too, replaced master cylinder, calipers, flex lines, rotors, booster, and bled the entire system. Then i took to brake check and they told me i had some leaking wheel cylinders in the drums in the back. After i replaced those it stops a lot better now, but still a little mushy. 3rd gen brakes blech.
Old May 12, 2005 | 04:45 AM
Grizzly_Addams's Avatar
Car: 1991 Firebird
Engine: 3.1L V6 MPFI
Transmission: 4 Spd Auto + OD 700R4
I replaced both front calipers, pads, rotors, bled system. Brakes still mushy. I've mainly had all older cars and have learned to accept it. If I slam on the brakes they lock up and the car slides so I assume they are grabbing enough =P
However, getting out of my girlfriends 2001 Grand Am and into my 1991 Firebird always makes it feel like there is alot wrong with my car (Except of course for the handling!!) =(
Twin_Turbo
Mar 14, 2016 10:10 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
