need quick help
Old May 5, 2005 | 08:05 PM
bsw's Avatar
bsw
Car: 87 iroc
Engine: 355 tpi
Transmission: 700 r4
need quick help
Tonight I am installing the Baer 13 inch front track dual piston pbr caliper brake system on my 87 iroc with stock iroc 16 inch wheels. The measuring cutout fits the rim. I was told by baer they would fit. When I bolt the spindle assembly onto the rim just the caliper fins rub the rim. There is tons of clearance otherwise. It appears that they need to be grounded off a little. What gives? Is it okey to grind these, are they not for strength?
bsw
Old May 5, 2005 | 08:18 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I wouldn't grind anything...if they hit, and they shouldn't, use a thin spacer from a drum rear car to get the clearance. Why in the world you would spend that much money and want to start grinding on new parts is beyond me. Not bashing you but that's not the best idea. FWIW, I run 13" HDs which are the same as the Baer setup and mine don't hit anywhere.
Ed
Old May 6, 2005 | 08:45 AM
bsw's Avatar
bsw
Car: 87 iroc
Engine: 355 tpi
reply
Thanks Ed for the reply
I don't uderstand why they rub since there are people that use the exact same rim and Baer setup with no problems. Should it matter, are the spindles directional ie Left and right specific? Maybe I used the wrong one on my passenger rim?
Anyway what thickness spacer should I try to begin with? Where can I get one?
Many thanks for your replies.
bsw
Old May 6, 2005 | 01:35 PM
ebmiller88's Avatar
The rotors should be left and right specific but that won't be the problem, nor will the spindles as they will only fit on one side. The dealer can get that rear spacer and also check the classifieds. I think I have a set too, but I'm not sure. That's the easiest fix. Also, I'd call Baer and tell them your problem, maybe they can give you some assistance.
Ed
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
