manual brakes?
Old May 9, 2005 | 10:55 PM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
manual brakes?
im thinking of doing a manual set-up.
are there swap parts out there that make this a bolt on thing? im not looking to spend a whole lot of money for aftermarket ****. just maybe stuff i can go to the junk yard and use?
Old May 10, 2005 | 12:31 AM
nape's Avatar
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
You'll have to buy a manual master cylinder bracket from PA Racing and then get a Dodge (minivan?) master cylinder. After that, you'll have to redo the lines and re-drill the brake pedal higher up for a better pivot point so you have more mechanical advantage (leverage).
I looked into it, and couldn't justify the cost just to reduce the weight. The booster looks big, but it's only about 8lbs IIRC. Not positive on that though. About the only time I'd think about it again, is if I was trying to stuff a big block under the hood.
Old May 10, 2005 | 09:22 AM
daturbosix's Avatar
Car: '92 Firebird
Engine: Poncho 455
Transmission: TH400
Axle/Gears: 12bolt
but what about the our stock proportioning valve and calipers, and rear wheel cylinders? can i use all of those still if i convert?
Old May 10, 2005 | 02:55 PM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Transmission: glide\ford 9"
When I switched to manual brakes I first used a S-10 master cylinder and stock disk/drum proportion valve and it all worked ok. I didn't use any kit but just made a plate that bolted to the pedal frame on the engine side of the firewall. I changed the pedal ratio to about 6 to 1. I also used the stock linkage and just turned it to length on my lathe. I now am using stock front brakes with svo explorer disks on my 9". I also updated to a strange master cylinder ( mopar type ) and wilwood proportion valve. I did away with the stock proportion valve. Manual brakes will never feel like power so you do have to push harder. Seems to stop ok.
Old May 10, 2005 | 04:29 PM
dual_88s's Avatar
From: In my own little world - but they know me well in here
Car: 88 Sport convertible
Engine: 305TBI
Transmission: AUTO
Axle/Gears: 3.42 rear end
Seems to stop ok.
OHHHHHH now that's encouraging.....wouldn't want to be behind him in a panic stop....
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
Vintageracer
Jan 10, 2020 05:33 PM
kyleb24
Aug 15, 2015 08:24 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
