Calipers and bleeding
Old May 18, 2005 | 04:10 AM
ponykiller1992's Avatar
Car: 89 formula 350
Transmission: Stock 700r4
Hey, the car I just bought is going to need front calipers, it dives to the left or right when you get on the brakes, which I am pretty sure means calipers. I just need to know how I go about bleeding the brakes after I put on the new calipers.
Old May 19, 2005 | 05:28 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
calipers may be ok it could be the lines. the poriginal rubber lines have a tendacy to close down with corosion. i would also check the slides they often hang and can cause the same pulling.
bleeding brakes is easy takes two people one holds pedal other opens bleader pedal hits floor close bleader pedal person pumps slowly back up and repeat.
jeff
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
the_hamturdler
Sep 30, 2015 12:50 PM
