How to adjust rear disc
Old May 23, 2005 | 10:38 PM
Allan Dollaway's Avatar
Car: 1988 trans am
Engine: 305tpi
I just put on some Autozone calipars for the rear of a 86.auot trans...I loaded the pads and bled the brakes but upon starting the car the pedal went dead,bled all the lines with new fluid.I read the Haynes manual for adjusting them,but not a very good description.Do i need to turn the piston out before hand to take up some play? After bleeding I still had a lot of slop with the pads backing off.I read all I could find in all the forums and could really use a step by step!!! any takers??? They had the e-brake cables unhooked for a long time and the left one needs to be replaced,froze. Thanks Allan
Old May 23, 2005 | 10:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Apply and release the parking brake until the slack is taken up.
Old May 24, 2005 | 09:48 AM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
I usually screw in the **** on the back side of the calipers by hand before connecting the emergency brake line, but then again I think the 85 setup is different from the 86 and up stuff.....
Old May 24, 2005 | 02:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, it was all the same from 82 through 88.
Old May 25, 2005 | 08:46 AM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
In case you don't know...pop the caliper around the rotor and bolt it into place before messing with the E-brake shaft. That shaft on the outside is really a bolt on the inside that has very (~60*) steep threads. 2-1/2 turns MAX and the piston will pop right out the caliper. I'd agree with Apeiron and say just apply the E-brake a few times. On new Delco iron calipers this should always work. I also read on here that someone else recommended applying the brakes and then quickly letting off and slamming them on to force the piston out against the pads/rotor. When I did my axle swap this last weekend, it was with an 87 Firebird so I should have the same calipers as you. The "Brake-QuicklyRelease&Slam" method worked fine for me.
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
