Front pads loose?
Old Jun 16, 2005 | 06:45 AM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
Front pads loose?
I've done a search, but to no avail. I can move the outer pads around on my front brakes. Of course the caliper prevents the pad from going astray, but is this movement normal.
(My first thirdgen, my first US car)
Cheers,
Mark.
Old Jun 16, 2005 | 06:55 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There are two tabs on each pad that should be clamped tight. This is done after the pad is put onto the caliper and prevents it from moving around.
The tabs are on the spindle end of the pad (this is where a pic is worth many words. . .) with a tab toward each end. Using a large set of pliers the tabs get squeezed up toward the top or outer edge of the pad. The pliers need to grip the top of the pad while squeezing the tabs.
RBob.
Old Jun 16, 2005 | 11:04 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Those tabs will unbend under extreme heat when using the 10.5" brakes under harder racing conditions (small heated spurts like AutoX or very mild track use).
The rattle and clicking always comes back from heat, Hence why I ended up building and entirely new brake system just to get rid on the constant always returning rattling noises that happened for years of embarassment. My old brakes worked great, just made noise.
The tabs in questionare circled with yellow. use channellocks like the wrench in the picture and place the jaws of the channel locks where I placed the green slashes. I even tried putting the red goo brake noise suppressant rubbery crap under those tabs and chnched them down- the noise would always return within about a month or two of normal hard street driving(or first track driving.)
Old Jun 16, 2005 | 11:14 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I do somewhat as Dean suggested; except, I bend the tabs in before I put the pads on, in small increments if necessary, to get them to a point where they grip the caliper tightly. I like to get them to where they need a small boost from pliers or something to push them all the way into place.
Old Jun 16, 2005 | 11:24 AM
Difflock's Avatar
A picture is indeed worth a thousand words!
Many thanks for all your help and replies.
Mark.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
deracer
Apr 11, 2016 12:04 AM
LittleFranks
Sep 17, 2015 12:22 PM
