swapping rear
Old Jun 16, 2005 | 09:08 PM
Tonyrodz's Avatar
Transmission: auto
swapping rear
can the pv from a drum car be used w/a disc rear? I plan on swapping out my drum rear to a disc rear and I need to know if I can reuse it.
Thx.
Old Jun 16, 2005 | 09:13 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
I usually change it. The GM part #'s are different for both.
Old Jun 16, 2005 | 09:16 PM
Tonyrodz's Avatar
Transmission: auto
Could/would it work tho?
Old Jun 19, 2005 | 04:50 PM
Tonyrodz's Avatar
Transmission: auto
anyone?
Old Jun 20, 2005 | 11:38 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Go ahead. I use my stock drum prop valve for my LS1 disc rear. Granted, I have 13" C4HD brakes up front. I'll be gutting it and adding an adjustable valve one of these days..
Old Jun 21, 2005 | 12:32 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes, but it may depend on the year of your pv. Here's my contribution on the subject a few years back:
https://www.thirdgen.org/techbb2/sho...&highlight=J65
I had a bias issue when I first swapped in a '88 9-bolt posi disc rear end in my 90 RS. I swapped PV's a few times to no avail. A leaking brake line turned out to be the culprit.
Lon
Old Jun 21, 2005 | 07:09 PM
Tonyrodz's Avatar
Transmission: auto
WHEW!
WHEW! Lots of reading!
Ok--so it looks like I'll be ok then since I'm putting an 86 rear--which will have an 89 rear disc setup--into a 92 rear drummed car--so it'll be a direct swap w/no other issues about master cylinders or pv's.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
E Rod
Aug 28, 2015 05:17 AM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
