master cylinder
Old Jun 21, 2005 | 02:06 PM
blackroc68's Avatar
master cylinder
Is there a differance between a rear drum brake master cylinder and a rear disk brake master cylinder?
Old Jun 21, 2005 | 02:15 PM
kaupca's Avatar
Car: 92 Camaro RS
I don't believe there is but you might want to get an opinion from others.
Old Jun 21, 2005 | 06:19 PM
Dirtbik3r's Avatar
Car: 1992 Camaro RS - not real slow anymore...
Engine: SPDC 360 MAF EFI /w a Holley Stealth Ram
Transmission: T5 untill it blows up from to much torque
Axle/Gears: Ford 9" /w auburn pro & 3.89's
No, there is definetely no difference. Just make sure your front lines are hooked up to the bigger part of the MC. I needed a new MC for my `92 Drum rear camaro. When i went to buy a new MC, there wasn't a difference. That is how I know.
Old Jun 21, 2005 | 11:03 PM
Dirtbik3r's Avatar
Just found out that prior to 1990 thirdgen's, they are different.
Old Jun 22, 2005 | 09:52 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
So does that mean a 90-92 will bolt up to my 89?
Old Jun 22, 2005 | 12:23 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
yes
Old Jul 1, 2005 | 12:05 PM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
What part numbers are you guys going by? I have looked up both the 89 and 91 MC and found that the part numbers are the exact same for each year. I must be missing something. Are there 2 different MC's for the drum and disc rear ends?
Fireslash
Apr 11, 2016 06:43 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
jaridjohn
Oct 5, 2015 07:01 AM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
