Squeezing piston into caliper w/ e-brake?
Old Jul 13, 2005 | 06:34 PM
Nitsuj86Iroc's Avatar
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
Ok, im on my rear brake calipers now and iv got to push the piston into the caliper. this is an '86 brake caliper. iv got a big C-clamp squeezing the face of the piston and the bolt head holding the emergency brake lever on. This thing wont go anywhere. i can push the brake pedal and get the piston to come out, then squeeze it back in to that same position, but no further.
Do i need to do something to back the emergency brake out to allow the piston to push into the caliper? Iv got a feeling that is what it is, but how do i do that.
iv done this on front brakes but never the back with the e-brake. thanks for any help on it
Old Jul 13, 2005 | 07:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The piston doesn't press in, it screws in. Rotate the piston while you apply pressure.
Old Jul 13, 2005 | 07:41 PM
Engine: 305ci TPI
ooo, thanks so much, that solved another problem i didnt even bother asking... why the hole for the bump on the brake pads were not aligned right
thanks for the quick relpy
Old Jul 15, 2005 | 03:46 PM
Engine: 305ci TPI
I assume that you mean apply pressure to the face of the piston right?
This piston will not spin, iv sprayed PB Blaster inside the rubber boot even becasue the boot was ripped, and it just will not turn. if i weret o take off the e-brake lever, or turn that bolt, would anything help me out?
right now the piston is about 3/4" out from the caliper.
thanks for help
Old Jul 15, 2005 | 10:08 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Apply pressure to the face of the piston while you rotate it in carefully with a pair of large slip joint pliers, preferrable without tearing the boot. There's a tool available to do it easily, but it's not entirely necessary.
zimmstoy
South Central Region
24
Dec 26, 2004 07:19 PM
matt formula
Jul 6, 2004 05:57 PM
Thirdgen86TA
Jun 18, 2004 11:16 PM
Jeff Hauge
Jan 7, 2001 05:25 PM
