Did I bleed my brakes correctly?
Old Jul 25, 2005 | 11:27 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
I bought one of those one man brake bleeder kits from Autozone today to bleed my rear brakes. It was dark and I was in a hurry....and I didnt notice the long hose in the kit. I ended up using a 6" hose that apparently is used to bleed the master cylinder. Anyways...i connected everything up, opened the bleeder screw, and immediately the brake fluid came out, and after a couple seconds there were no more air bubbles.....easy enough.
However, I was apparently supposed to use the longer hose. I was able to keep the bottle above the bleeder screw, but do I need to go back and redo it using the longer hose? Does the length make a difference? I still havent had a chance to test the brakes out. It wont take long to redo but it'll save me the time to get under the car if I dont have to. Thanks a lot.
Old Jul 26, 2005 | 07:58 AM
92_ZED's Avatar
Car: '92 Z28
Sounds like the brakes bled out the air. Best way to tell is to start the engine and push on the brake pedal (leave trans in neutral or park). If the pedal feels spongy then there is still air in the system.
Al.
Old Jul 26, 2005 | 08:41 AM
mult68's Avatar
Engine: 305 TBI
well if thats the case that kit they sell is awesome. Ill check the brakes tonight
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Apr 30, 2019 12:14 PM
backtothe80s
Sep 5, 2015 12:39 AM
g.l.mos
Aug 22, 2015 12:02 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
