rear calipers
Car: 1997 Camaro z28
Engine: 350 LT1 built to LT4
Transmission: a
Axle/Gears: 3.23 posi
rear calipers
ok, so I just bought a disc rearend for my car out of a 91 GTA Trans Am, but it didn't come with calipers or pads.
what I'm wondering is, were there any other cars made at a similar time that use the same calipers, so I can get 'em from a junk yard and either put 'em on my car or use them for the core charge?
also, when I go to autzone/advance auto to get the new calipers, does anyone know if I'll be getting the better aluminum calipers that came on the later models or the not so good ones that were on the earlier years?
and has anyone heard of abs on thirdgens? a friend swears up and down that his old 89' had abs and that the whole underhood brake setup did not look like mine. he also had rear drums, if that means anything.
I doubt it, but like I said, he swears up and down that he had it.
thanks for any help.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Re: rear calipers
Ed
Transmission: a
alright, but were there any other cars than f-body's that I could look to for the calipers?
rear disc on f-body's is damn near impossible to find around here, period.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Cast iron Delco/Moraine calipers aren't interchangeable with the aluminum PBRs. If you go to the parts store and ask for the calipers for any rear disc Camaro or Firebird from 1988 to 1997, you'll get the right calipers.
Transmission: a
cool, but were there other cars that used them?
or trucks?
i need something to pull it off of, if possible.
or trucks?
ambainb
Apr 25, 2016 09:21 PM
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
