Removing old Front brake hoses
I am trying to remove my front brake hoses on my 82 camaro, I have tried heat no luck. what is the easiest way to remove them i tried loosing line it just starts to round off. I have tried penetrating oil to loosin things up but no luck. Any help would be greatly apprecited. I haven't driven my car in over 3 years. Would like to drive it soon. Please any ideas let me know.
Thanks,
Justin
Thanks,
Justin
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
are you using line wrenches.....i didnt know about these my first time and almost rounded em off to the point of no return
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Good you see you got it off. For anyone reading this that actually stripped the fitting like I did you can use a dermal tool and grind down the fitting into a rectangle and use an adjustable wrench to get it off. Here's a pic.
Axle/Gears: 3:08
Good tip..never thought of that....and its dremmel..i believe...just to let ya know
1992 Trans Am
May 10, 2023 07:19 PM
