Baer Tracck rear conversion fit?
Car: '88 IROC Convertible
Engine: ZZ4 TPI
Transmission: 5 spd.
I am swapping the rear drums to the Baer track system, I am also running IROC 18's and an air ride technologies suspension.
Right now side to side clearance is tight, will the new Baers "push" my rims outward at all?
If you've installed the Track system I sure would appreciate your advice.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
I converted the iron calipers to the PBR Baer kit - they are exactly the same as stock - its due to the rotor mounting flange being the same thickness between the old 10.5" rotors and the 12" new rotors. I'm sure it work the same for the drum conversion.
ambainb
Apr 25, 2016 09:21 PM
I'llrocya
Feb 2, 2016 11:43 PM
