Drum-to-Disc Conversion??
Old Aug 19, 2005 | 03:54 AM
zclone's Avatar
Well I've read everything here, And all the Ebay adds, and listened to all the know-it-alls and bought two books on how to hod rod third gen Camaros. I have come to the conclusion that converting to any kind of disc brake rear that is set up with drums, is not possible. No where, not even here, can anyone tell me how to go about it, especially how to remove the drum setup and what I need to do, if anything, to mount anykind of disc setup.
I've got a complete single piston aluminum PBR setup I'd like to install, but I don't see anyway that those drum setups are coming off the axle housing. After I torch them off, what then? Pull the axle out, and weld the new mounting plate to the axle housing?
If there is a book that will tell me the step-by-step, I'll buy it, heck I'll Paypal anyone that walk me through this. I'm surprized this site doesn't cover this......Zclone
Old Aug 19, 2005 | 03:57 AM
zclone's Avatar
I have a 92 Camaro, that has been very meticulously conververted to a Z28 except for the rear end which obviously is still drum.
Forgot to mention that. zclone
Old Aug 19, 2005 | 07:11 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Many people have done the swap on this site (you sight consider the search function).
Modify the axel flanges to accept the correct backing plates:
https://www.thirdgen.org/newdesign/t...reardisc.shtml
Here's what you need:
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
Old Aug 19, 2005 | 05:06 PM
jimp2001's Avatar
Car: Red on Red 89 RS
Engine: LO3 305 TBI
Transmission: TH-700R4
Axle/Gears: 10-bolt / 2.73
edit...
making new topic for my questions.
Old Aug 21, 2005 | 08:53 PM
KnightWarrior's Avatar
Car: 1985 Camaro Z-28
Engine: 305 V-8 4BBL (H) Supercharged
Axle/Gears: 3.42 Eaton Posi
Why bother? Just find a disc-brake rear at a wrecking yard, rebuild it and bolt the whole thing in. Much easier than fiddling around with a drum rear trying to make it into something it isn't.
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
