Quick question-can some help me find the dimensions of the 1LE banjo bolts?
Old Aug 28, 2005 | 11:25 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
If I look them up at my store it only gives the part # for non-1LE iron calipers which are M10-1.50. Are the 1LE the same with a different pitch? maybe M10-1.25?
Also how long are they supposed to be?
Old Aug 29, 2005 | 01:13 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
IIRC you work at Auto Zone. You should have a big bin of banjos and crush washers in the back, the right ones should be in there. I've had luck getting them from AZ in a pinch, otherwise I use GM. I do know it's a M10 x 1.0mm pitch and should be around 20-25mm long off the top of my head.
Ed
Old Aug 29, 2005 | 04:50 PM
GASGZLR's Avatar
Thanks Ed, looks like I am going banjo bin diving.
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
