This is what bad brake hoses look like
Old Aug 28, 2005 | 11:50 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Well here is some pictorial evidence of bad third gen brake hoses. I knew that they where something that needed replaced, however when one became a one way valve, it became immediate.
They don't look to bad from a far but they are. I remember the small cracks the last time I took the wheels off but not the big ones.
I would have failed safety inspection in my area, if these had been noticed.
$28.70 and an hour and I was back on my way.
Old Aug 29, 2005 | 08:10 PM
The Wizard's Avatar
Car: '85 Z28
Engine: 355
Transmission: TH350
I can relate.....Been there, done that......
Old Aug 29, 2005 | 11:48 PM
Car: 91 Camaro RS
What I couldn't believe was the change in pedal feel and brake bias. The pedal is much softer and the rears are working a whole lot more. And, Yes I've bled them enough.
Old Sep 5, 2005 | 04:15 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
And the scary part is... They were going bad inside long before they went bad outside!!!
Old Sep 5, 2005 | 07:49 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
those can go another 20k miles, man!
lol seriously though, I had one blow out on my way to work last summer. not fun at all. it was like $20 to replace... I bought one, then purchased Earl's SS brake lines, and cleaned then returned the rubber one. Couldn't be happier.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
dyeager535
Aug 28, 2015 08:10 AM
