89-92 PBR Brake Guys
Old Sep 5, 2005 | 06:33 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
What size is your factory spare tire?
JamesC
Old Sep 5, 2005 | 08:18 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
I bought one of the aluminum 1LE spares off e-bay for my car after the PBR swap but I think the steel one would work as my good friend has a factory PBR car with that spare.
Old Sep 6, 2005 | 08:42 AM
JamesC's Avatar
Is your 1LE spare the alum 10-spoke inflatable? If so, it apparently won't work. Any idea what size the factory spare is that your friend has?
JamesC
Old Sep 6, 2005 | 10:13 AM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
The 10-spoke aluminum deal is only like a 14" rim.
The other aluminum spare is 15", and is a solid disk -- lots of people assume it's steel because it's painted black.
Another option is the 16" spare that came with all '98-'02 fourthgens. Saves you having to mess with inflation cannisters. It's a very tight fit in the thirdgen compartment, but it will fit. (on my '83, it pushes the trim out maybe 1/2" further out then where it's supposed to be. (which isn't noticeable with the hatch closed, obviously)
I have a HD Baer kit on my '83, and the 1LE spare didn't quite fit. The '98-02 spare worked fine.
FYI, later C4 'vettes supposedly had a 17" spare, but I've never used one.
Old Sep 6, 2005 | 10:21 AM
JamesC's Avatar
Maybe I didn't make myself clear enough (bad habit). Is the 89-92 spare, used with PRB's, a P195/75-D15?
JamesC
Old Sep 6, 2005 | 11:23 AM
Dave_Jones's Avatar
Nah, we're just easily distracted.
Yes, it is a P195/75-D15.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
aaron7
Exterior Parts Wanted
Aug 18, 2015 05:47 PM
Street Lethal
Aug 14, 2015 08:25 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
