Brakes chatter when going in reverse???
Old Aug 30, 2005 | 08:10 AM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I just had a Baer 4 wheel disc brake kit installed. . . a couple of questions/issues:
1.) When going in reverse, the rear brakes screech / chatter / vibrate horribly when I apply the pedal. This only occurs in reverse, and is far more prevalent when cold.
2.) The brakes aren't nearly as impressive as I thought they would be. . . and I can hardly tell much of a difference between them and the stock ones. Could this be a pressure issue or something? I do have the Baer proportioning valve turned up all the way for the rears, so maybe that has something to do with it?
Old Aug 30, 2005 | 02:11 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
As for the brakes not being impressive yet, how long have they been installed and used? It does take a "while" to bed the pads to the rotors and vice versa. My HDs didn't come into their own for a few months really, but when they did...Ohhhh man...what a setup. As for the prop, IMO I'd dial it down until the brakes bed in and then play with the tuning when the brakes can grab. I'm sure other guys that actually run one can give you more help with it.
Ed
Old Aug 30, 2005 | 03:03 PM
Car: 91 RS
Engine: 350 TBI
Ed
They have about 120 miles on them. Any idea as to why the vibrations in reverse occur or is that tied into the whole setting thing?
Old Aug 31, 2005 | 07:18 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
The PBR set-up from Baer is identical to the OEM set-up from 88-89. All of them had scrubbing sounds when reversing so GM put dampeners on the 90-92 models. They look like a 3" rubber doughnut on a stick and attached to the caliper. It's only annoying, nothing that can be dangerous or cause any damage.
Old Aug 31, 2005 | 08:26 PM
Car: 91 RS
Engine: 350 TBI
Do you have any pics of said donunt thing? If this and the general noisiness continue (the rears squeal under lateral load), I'm going to take them off.
Old Sep 1, 2005 | 12:28 AM
ebmiller88's Avatar
They're on 4th gen PBRs...I take those things off all the calipers I work with, I have 30 of them in my shop. Here's a fuzzy pic:
Attached Thumbnails Brakes chatter when going in reverse???-untitled-web.jpg
Old Sep 1, 2005 | 07:28 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
What lateral load are you talking about, turning??
Eb,
I might take a pair of those off your hands!!
Old Sep 1, 2005 | 08:56 PM
ebmiller88's Avatar
No problem, yours for shipping cost...hell...want 2 sets?
Ed
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Sep 19, 2015 08:13 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
