'06 ZO6 brakes
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
'06 ZO6 brakes
Well here's a shot of the whole front and rear caliper setup for the new ZO6 14" brakes. Looks like a 6 piston caliper with 6 pads, 1 for each piston. They look like a lug mount caliper so I'm sure "we" can come up with a bracket to make them work but I"m sure they'll take a 18" wheel to fit them.
And here's what they're currently going for:
http://cgi.ebay.com/ebaymotors/ws/eB...BUAA%3AUS%3A72
Ed
Ed
That is a very nice way to go-Why?- Because you will have unlimited options in the near and very distant future on brake pad compound choices.
Thats my only drawback when I used the Wilwood SL-6 calipers, I am limited on pad choices. Every manufacturer and their brother will be making pad compounds for factory Vette calipers.
In 8 months I am finally just barely starting to get low speed pulse moan with the EBC greens. Greens are notorious for leaving pad "build-up" on the rotor face and giving that warped feeling. I will need to pull them down in a month or two and turn them clean. I am going to try the Hawks HPS street pads next to see if they are any better. Plus the EBC's have too touchy of an initial bite- not smooth until they are heated, then they fade easy above 600* which isn't much heat tolerance the way I drive.
If only Stillen made pads to fit the SL-6 calipers, itwould be a perfect world for me.
I just had a thought...I'll bet you can fit up those rear calipers for a front kit just as well...
Ed
Ed
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
id like to get those on my trans am , i want more brakes, just for looks and shows and stuff. I dont think they will fit my wheel with the stepped lip .
I thought that was odd myself...note how he ended the auction early. Guess he wasn't getting what he wanted for them.
Ed
Ed
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
lol, i looked and seen .99 for the amount, then seen it was ended by seller. guess nobody bid enough. i wonder how much these will go for when they become easier to get.
those would look nice under a set of 18's wouldnt they
thanks
anthony
thanks
anthony
I need to get some parts from Dal so I'll check prices and availability with him at that time. I'm sure they are some sweet calipers.
Ed
Ed
i would say so being the car has been tested at nurimbirg f1 track with no brake fade. i would love to have that setup on my car.
..................... so how long before you toy around with it on yours ed?
thanks
anthony
thanks
anthony
No time soon my man...I still have the new Wilwoods on the floor in the shop.
Ed
Ed
thats cool. i have yet to buy upgraded brakes for the t/a yet because i have more important stuff to get for it. but i am trying to decide what to get. i might price this stuff new from gm with my 25 % discount. i will do a little research.
thanks
thanks
Car: '91 vert RS, '82 Z28
Engine: TBI 305, TPI 350
Transmission: Auto, 5 speed
what size are the front rotors for the 06 vette. im in the middle of doing the 98 + style i could always return everything i bought and buy the 06 stuff.
yea there 14" drilled and sloted fronts with 6 piston calipers, rears are 13.4 with 4 piston calipers!
that would really fill up the wheels wouldnt it.
thanks
thanks
Just to be clear, only the Z06 Vettes get the 14" front brakes, the other C6 "Z51" cars get the same C5 12.75" brakes. I still think we can use the rear calipers for a front kit using the C5 12.75" front rotor.
Ed
Ed
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
id like to put those 4 piston brakes on the front too, ed you should find out if they fit , i may think about doing it and sell my c5 stuff.
thanks
thanks
they might be, i was just typeing what motor trend had in there last article on it, but they have been known to be wrong in the past on stuff like this.
thanks
thanks
" Ed you should find out if they fit "
If someone sends me a caliper I'd be glad to, no problem...I've got a lot of money tied up in parts right now and the piggy bank is a bit low. I'm still trying to unload a lot of parts as it is...
Ed
Ed
I'll save you guys some work and money... the C6 ZO6 front brakes are a direct swap for the standard C5 brakes. this means that the brackets that are already made up for the C5 brake swap will work for the C6 ZO6 brakes. the real trick will be to fit the rears from that setup on the rear of a third gen. Thats something i'd like to find out, and am looking to do, as soon as pricing is out for all of the parts... and hears a thread with much better pictures and install pics..
http://forums.corvetteforum.com/show...347&forum_id=1
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
o man thats awesome , so they just bolt on , i wanna get a set for the front of my car. does anyone know how much they are for the calipers rotors and pads from like gm partsdirect since their the cheapest .
Good grief those brakes are friggin huge! It's a HUGE plus that they bolt right on....you guys with 18" wheels should be going crazy.
Thanks to BN for the link.
Ed
Ed
Car: 91 Formula, 95 GT
Engine: 5.7, 5.0
Transmission: T5, T5
Axle/Gears: 3.42:1, ???
Originally posted by ebmiller88
you guys with 18" wheels should be going crazy.Ed
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
Wow, and I thought the C5 calipers were big when comparing to the stock thirdgen calipers.. They look like midgets compared to the C6 calipers.. Even though I just did the C5 upgrade, I can't help wanting 18's in the front instead of the 17's (have 18's in the rear) and the C6 brakes
(not likely to happen in this lifetime unless I win the lottery). It's not even that I would need that much braking power either, it just looks cool
So these just slip right over the rotor with the pads in place and bolt to the bracket and you're done? If so thats much easier than bothering with the caliper bracket and greasing pins.
im now looking for a disc rear to have as a mock up axel... i am going to try and retrofit the C6 ZO6 rear brakes onto a 3rd/4th gen rear end. i also talked to the people that make the 18 x 8.5 replica irocs and i can get a test wheel from them to check clearances... as soon as i get a rear and the parts become avaliable im going to start the project...
Car: 1992 Jade Green---Trans Am Converti
Well the rear C5 calipers are the same as the rear LS1 fourth gen calipers, and all three rotors use a drum style parking brake. Should bolt on the same as well right?
Kevin D.
Kevin D.
Kevin D.
Kevin D.
just got off the phone with Fred Beans, parts or pricing wont be avaliable for another 30 days there estimating.... rough guess from them for 4 rotors, 4 calipers, and all brake pads is $1,500 - $2000... if people are still interisted i can contine to push forward with the project....
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
Man I would love to have those instead of the C5 calipers. For now though I am going to focus on getting body work and paint done! Keep us posted, I would definitely be interested in doing this mod down the road and hopefully prices will drop a little.
nothing as of now... i havent put a whole lot of time into this, ive been busy with a new job, and as far as i know parts have not been released yet, also the wheel issue is another problem, i dont know if i want to run the 06 zo6 wheels and spacers on my car... need to do a little info gathering on that too...
nothing as of yet. I know the parts manager pretty well, and he said chevrolet has not given them the parts catolog for the zo6 specific parts yet, hell they just got an 06 zo6 on there showroom. let me tell you, i had a hard time not drooling over the fenders lol. When i find anything out, i will post updates, but i was told that it may be a couple more months before a mass release of parts.
thanks
anthony
thanks
anthony
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
You will defitely need 18's. Also, as incredible as the system is $1500 is not cheap. Personnaly I would only spend that much on a brake system is if it was for a track car, not a street car. If a full 13" brake system is not enough for the street, I'm either driving too fast or towing a trailer...
Ben
I can't believe I just said 'driving too fast' I must be getting old er something.
Ben
Originally posted by b's90cam
I'm wondering if the c5 17's might possibly fit, the c6 zo6 has 18 huh?
Car: 87 iroc 89 pearl white' black 06gto
Engine: 350 Procharged AFR, T76 383 miniram
Transmission: 700r4, 700r4, LS2 t56
it was only a matter of time... if you decide to grab these remember that they are drilled, so they will crack, not if but when, and they are directional for the right side of the car only, IE putting the rotor on the left side it has the vanes going the wrong way... gm's way of saving a buck.
dbrochard
Sep 19, 2015 08:13 PM
