booster/Master cylinder question
Old Sep 16, 2005 | 05:23 PM
PDubs87Z28's Avatar
Car: 87 Z28 Hardtop
Engine: 305ci-4bbl
Transmission: 700R4...3.27 posi being installed
I have to do a rear swap from drum to disc. Now i know need a new brake booster now because mine is bad. when i swap do i really need to change the master cylinder/and booster? I got a new prop. valve so thats good to go but does the booster and MC need to be swapped as well.
The reason i ask is because i need a new booster ASAP and the rear swap will be done in late fall/early winter and im looking up boosters and they have packages @ rockauto.com of boosters/MC for drum and set for disc.
Old Sep 16, 2005 | 09:04 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Keep your master cylinder as it is correct, unless it's bad or something.
Ed
Old Sep 17, 2005 | 05:35 PM
PDubs87Z28's Avatar
Car: 87 Z28 Hardtop
Engine: 305ci-4bbl
Ed
But should i change the booster as well or does it not matter?
Old Sep 17, 2005 | 10:29 PM
ebmiller88's Avatar
Unless the booster is bad leave it alone.
Ed
Cornholio7979
Sep 20, 2018 02:31 AM
fasteddi
Sep 2, 2015 10:29 AM
NinjaNife
Aug 23, 2015 11:49 AM
db057
Aug 22, 2015 08:17 PM
redmaroz
Aug 16, 2015 11:40 PM
