Master Cylinder / Brake Booster...!?
Old Oct 3, 2005 | 07:39 PM
Orizon's Avatar
Car: 1984 Trans Am
Engine: BuiLt 350! Hooker 2055's
Transmission: T5-manual trans-centerforce clutch
my car sprang a brake fluid leak between the master cylinder and brake booster, does this mean one or both of them are bad or id there a seal there that it could be and niether one is bad? i dont want to drive it like it is, brake fluid being corrosive n all.
Old Oct 3, 2005 | 08:06 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
master cylender is shot, Ive seen the brake fluid also eat the seal in the booster so you want to check that too while you have the cylender off.
Old Oct 3, 2005 | 10:18 PM
Orizon's Avatar
Car: 1984 Trans Am
k thanks, ill pull it apart after work tomm. hope booster isnt shot.
db057
Apr 28, 2019 07:45 AM
dbrochard
Oct 3, 2015 12:43 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
