Banjo bolt torque specs
Old Oct 3, 2005 | 07:40 PM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
What is the torque spec for the banjo bolt when using aluminum calipers? Is it the same as the stock cast iron or less? I know that aluminum is a much softer material so I'm concerned about over torqueing the bolts on my SSBC Force 10's
Old Oct 3, 2005 | 08:55 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The spec is only 12 ft-lbs on aluminum PBRs. Did you go with the Force 10 2-piston replacement calipers? Curious..
Ed
Old Oct 3, 2005 | 11:43 PM
JDF-Z28's Avatar
Car: 1983 Z28
Yes sir, the twin pistons. I had read 12 somewhere but wasn't sure. Seems so low. They brakes seem to grab really good but I want to bed the pads before some really hard testing...
E-mailed SSBC Tech also to be sure. It doesn't give banjo torque in the installation instructions.
AussiePr0nCar
Mar 6, 2020 04:04 PM
redmaroz
Apr 25, 2017 07:14 AM
deracer
Apr 11, 2016 12:04 AM
gixxer92
Sep 1, 2015 04:32 PM
