Line Lock Wires
Old Oct 13, 2005 | 01:56 PM
chio987's Avatar
Car: 84 Firebird Trans Am
Engine: 305 4bbl HO
Transmission: 700-R4, 3.73 rear
Line Lock Wires
I'm putting in a line lock and was wondering if i need to use an inline fuse when wiring it up ....i didn't get instructions
Old Oct 13, 2005 | 02:41 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
All circuits in your vehicle should be protected by a fuse or circuit breaker.
Old Oct 14, 2005 | 11:19 PM
chio987's Avatar
Engine: 305 4bbl HO
what fuse should i use....10amp??
Old Oct 15, 2005 | 11:15 AM
dankhound's Avatar
Car: 91 RS
Measure the resistance of the solenoid. Then use the formula
E=I * R
E is voltage. Id used 14v for that
I is the current or amperage. Thats the number you are trying to find.
* is what i use for the multiplication symbol.
R is the resistance. You measured that.
Youll want to use a fuse higher than that but not by much. Make sure the wire you use is capable of carrying the current also.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Jake_92RS
Aug 17, 2015 09:42 AM
Zachattack0925
Aug 12, 2015 09:52 PM
