1LE Master Cylinder specs. And LS1?
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
What is the diameter of the 1LE master cylinder bore? I'm trying to figure out some math for converting to manual brakes with a big brake setup and was wondering what the bore was of the 1LE master. The LS1 master bore size would be nice to know too. I couldn't find anything in my searches about the size of the bores.
How do they compare to the stock master?
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Car: 1997 Corvette
Ah ha, thanks. I was mainly searching for the 1LE stuff, but the LS1 info is just as good. I figured I'd throw it in as part of the question. Thanks. Now to do a bit more research and I may finally make a decision on this stuff.
EDIT: Actually I just re-read that. So there really isn't much difference at all between the actual master cylinder side of things. I figured the LS1's had a different size MC, but apparently not noticeable.
88SS6SPEED
Nov 11, 2015 07:05 AM
codeysabatini
Nov 10, 2015 04:07 PM
camaro1185
Oct 26, 2015 06:51 AM
