brake conversion
Old Oct 20, 2005 | 08:49 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Transmission: TH400, Freakshow 9.5"
Axle/Gears: 9" 4.71
brake conversion
Looking for some fab help, looking to switch over to a 9 in. My 7.5 has the rear disc setup, and wondering if anyone has tried putting them on a 9 in housing, my rotors, pads, and suprise, suprise--calipers are new, so no worry about them. Any Ideas???
Old Oct 23, 2005 | 07:24 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you're talking about 9- and 10-bolt rear discs, the only difference is the backing plates.
JamesC
Old Oct 23, 2005 | 09:08 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
He's mentioning a 9 inch, not 9 bolt, so it should depend on who made the rear and what flanges they put on it. If they installed "10 bolt" flanges on it, they should bolt right up.
Ed
Old Oct 24, 2005 | 08:45 PM
TA_drag's Avatar
Car: 85 Trans Am
Transmission: t5
I'm working on this right now. I am assuming you have a Moser rear? Here is a link to a thread about it. The link at the end by IROCZZ3 is exactly what I needed to figure it out.
https://www.thirdgen.org/techbb2/sho...ighlight=moser
Old Oct 24, 2005 | 09:25 PM
KWIK84's Avatar
Car: 1984 Z28
Engine: Alky 360
Axle/Gears: 9" 4.71
thanks for the post, i tried searching earlier, but way too much to try and look through to get what i wanted, the rearend is actually a "junkyard" assy that i had, have new gears and a spool to put in it, have cut it to size, welded my brackets on (using coil-overs) and working on a rear brace. Someone correct me if i'm wrong, but shouldn't the specs for the bearrings be the same no matter if it is a bolt in unit or not? Thanks
Old Oct 24, 2005 | 09:42 PM
TA_drag's Avatar
Car: 85 Trans Am
Transmission: t5
Originally posted by KWIK84
[correct me if i'm wrong, but shouldn't the specs for the bearrings be the same no matter if it is a bolt in unit or not? Thanks [/B]
I am not sure but I can tell you with my axles installed, my axle bearings protrude 1/8 inch past the housing ends. If yours is like this the diagram from moser should be what you need. I would just check the o.d. on the bearing before clearancing your disc brackets.
LittleFranks
Oct 7, 2015 11:26 PM
dbrochard
Sep 19, 2015 08:13 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
