1LE brake installation
Old Oct 21, 2005 | 11:21 PM
86 406's Avatar
Installing 1LE brake kit. Passenger side went together well. The driver side bolts together with the bleed screw at the bottom of the caliper. The bleed screw goes into a shallow beveled hole, and the supply line bolts into a deeper hole so it appears the two are not interchangeable. Am I missing something or do I have two passenger side calipers? Any Thoughts?
Old Oct 22, 2005 | 07:46 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A pic of the driver's side in the following link might be helpful:
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
Old Oct 22, 2005 | 09:49 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
The other side should be a mirror image. If you dont' have that, then my guess is that you have 2 driver's side. You should be able to tell by taking the bleeder screw out and looking into the hole.
Ed
Old Oct 22, 2005 | 02:04 PM
86 406's Avatar
1LE brakes
On closer inspection, it appears I have two identical calipers. The boxes they came in have different part numbers so a mix-up occurred somewhere along the line.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Adamki2000
Brakes
24
Dec 20, 2015 10:40 PM
gta90
Sep 15, 2015 04:00 PM
