e-brake cables
Old Oct 31, 2005 | 10:50 AM
Blkmaroman's Avatar
Car: 1998 zx9r
Engine: 899CC inline 4
Transmission: 6 speed manual
Axle/Gears: 15T front sprocket, 43T rear
e-brake cables
im switching from drum to disk and the rearend i got has the ebrake cables cut and the brake lines cut, will the brake lines on my drum 10 bolt unscrew and screw into my 88 9 bolt disk. And do i have to have ebrake cable right away when i put the disk rearend in, or can i order them and put them in later
Old Nov 1, 2005 | 01:50 PM
Blkmaroman's Avatar
Car: 1998 zx9r
Bump
Old Nov 1, 2005 | 02:25 PM
Axoid's Avatar
Car: 92 Camaro RS
Transmission: T5 manual
You will need new e-brake cables. I ordered a pair from the local Advance Auto Parts store and got them in a few days and for like $30.
Not having the brake cables will not effect driving the car, just parking the car if you have a manual trans.
Old Nov 1, 2005 | 03:23 PM
Blkmaroman's Avatar
Car: 1998 zx9r
thanks for the reply, i have an automatic so ill probably go ahead and put the rear axle on and install the cables later. I looked at the cable and i didnt really see a way to get them off because where they hook to the brake there is a spring and they dont unhook so how do you get them off. Thats probably why someone cut the brake cables in the first place
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
