Template needed
Car: 87 Trans Am
Engine: 434 being built
Axle/Gears: 3:73
Template needed
I'm looking for a template for the 1LE brake system. "Spindle Adapter Plate" & the cutting of the spindle. I could have missed it in the threads? Could use your help. Thanks...
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
It's hard to find so I recommend saving it somewhere on your puter. As for the bracket, I don't know if there is one for the 1LE adapter.
Ed
Ed
Car: 87 Trans Am
Axle/Gears: 3:73
How about the adapter plate?
Would you know where I could get the adapter plate template from. I have a good friend that owns a metal fabrication shop that I could have it made free. I could even have you made up some! GM wants $91.00 per pair & it go's up from there. Thank you so much for the spindle template. Sorry, its early and didn't read all the post. about the plate. If anyone has one, I could use the thickness & I could most likely come up with the rest. Thanks again
Greetings sent from Goose Creek, South Carolina
