Right Prop Valve for 1LE
Old Nov 12, 2005 | 05:06 PM
Parrydise7's Avatar
I added 1LE brakes to the front of my 1985. I still have the iron Delco Moraine brakes in the back.
When I originally made that mod, I didn't change the prop valve. After checking on this board, I thought I'd better change it so I bought p/n 14089496 prop valve from the dealer.
I took it to Dyno Don. When he compared the two (the one on the car with the one from the dealer) he said they looked the same.
It shouldn't be, but that's the way it is. Any ideas? (Yes, I did search). Thanks!
Old Nov 13, 2005 | 06:43 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I put the 1LE valve in my 85 IROC (and at the time it had the regular J65 rear discs). Worked great. Here's what the Camaro Parts and Illustration Catalog says: Valve, Comb (J65) (1985) 25521985. The stock p/n is clearly different from the 1LE.
1989-1990
Valve, Brk Comb (1989 1st Des) (J65, 1LE, Y82) 14089496
There's also a second design 1LE.
JamesC
Old Nov 13, 2005 | 09:23 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Visually they will look the same, I can't tell them apart either. Difference is all internal.
Ed
Old Nov 13, 2005 | 10:22 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I checked with the dealer in the area and verified the #14089496
is listed as all '86-'92. Maybe it's just a retro.
Old Nov 13, 2005 | 11:33 AM
JamesC's Avatar
Could easily be--this is GM after all. For the heck of it, I looked up the valve for J65 brakes, 1986-88 and 89 (Exc 1LE ) and the p/n number is 14089497. Darn close.
At any rate, Parrydise, I'd throw in the 1LE valve.
JamesC
Old Nov 13, 2005 | 11:38 AM
Parrydise7's Avatar
Gentlemen,
You have been exceptionally helpful and I greatly appreciate it.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
Necron
Brakes
Sep 14, 2015 12:45 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
