4gen on third gen
Old Dec 2, 2005 | 01:11 PM
cam406406's Avatar
Car: 1989 TA
Engine: 406
Transmission: 400
Axle/Gears: 9 inch
4gen on third gen
i have seen a conversion like this on a site befor bt cant find it again can u help they also had a corvette conversion for a third gen please help me
Old Dec 2, 2005 | 07:21 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Front brakes right? What info do you need? I've done both of those conversions:
http://pg.photos.yahoo.com/ph/taramiller72/my_photos
Ed
Old Dec 8, 2005 | 08:29 AM
Jeffluke's Avatar
Car: 90 L98 IROC/87 LB9 NM5 1AZ / 96 TBI 350 700R4 XCAB S-10..LT1 SOON
Engine: L98/LB9/LT1
Transmission: 700R4/WC-T5
Axle/Gears: 3:73
Brake upgrade
I am about ready to do my brake upgrade for the front of my car, not trying to rehash topics as the brake threads keep getting better and better, but if you know of a specific thread that would help me that would be great, after gathering all the parts over period of time, I am at a crossroad, just want to know anyone can give me your best opinion for the best brake setup with the parts I have, here is what I have:
(1pair) 92 spindles drillied cut and tapped
(1pair) LS1 calipers/rotors/carriers and adapter plates.
(1pair) used stock 3rd gen rotors
(1pair) used B4c/1LE rotors
(1pair) 1LE calipers w/pads and earls lines
(1pair) C4 13/hd carriers w/hardware
(1pair) 13in C4 hd/rotors
The car is an 87IROC J65 car, fresh master cylinder, w/LS1 rear brake setup, calipers mounted in rear position, 1LE earls lines, refabed ebrake cables and brackets and stock J65 prop valve, (w/17in rims).
Q: Can I use the 13in hd rotors, LS1 calipers/carriers, which hub?
and which thickness adapter plate? will it work? or are the
13in hd rotors too thin for the LS1 caliper. I prefer the LS1
caliper for its larger size and girth, and will tophat both
sets of rotors as the price is about the same. There is a lot
of brake threads out there, just didnt find the exact answer
I was looking for. Any advice or help would be great.
Hotrodboba400
Dec 10, 2019 07:07 PM
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Stryker412
Sep 7, 2015 09:11 AM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
