can I adapt Lt1 rear disc brakes to a 3rd gen rearend
Old Dec 22, 2005 | 05:41 PM
BOTTLEDZ28's Avatar
Transmission: A4
I have a 4th gen disc rear and I want to switch back to a 3rd gen rear and I need to know if the 4th gen LT1 rear brakes will swap over to a 3rd gen disc or drum rearend. If so, then all I really need is an empty 10 bolt housing and new axles. The rest should swap w/o problem.
Old Dec 22, 2005 | 08:33 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
if its a 10 bolt, and you have the correct bracket to fit your rearend, its a bolt on deal besides lines, and i think something special about the e brake.
its been a while since i helped do a set.
i believe they are close(or identical) to the 89-92 PBR system on 3rd gens.
Old Dec 22, 2005 | 08:35 PM
BOTTLEDZ28's Avatar
Transmission: A4
so as long as the rear I find has the original brake brakcets for the disc setup then I should be ok then. Is using a drum rear out of the question?
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
