Rear passenger drum failure effects front driver disc?
Old Jan 3, 2006 | 05:57 PM
80smetalfan's Avatar
Car: 1989 IROC
Engine: LB9
Axle/Gears: 3.42 Posi
Just as the title says, my buddy's rear passenger drum went out (from lack of maintenance) on his 89 RS, and now his front driver side disc brake (which has a new caliper/rotor/pad) begins to lock up after 10 minutes on the road. What could cause this?
The front caliper was replaced after locking up about 5 months ago, and has operated fine since. Should he just replace the whole brake system?
Old Jan 3, 2006 | 06:59 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Engine: Holley MPFI, AFR 195, Hot Cam=375HP
Okay, maybe this is a dumb question, does his rear brakes work now?
If he is driving around with just front breaks I'd imagine it's more heat than they can handle. I could explain vapor lock but a search would do just as much.
Ben
Old Jan 3, 2006 | 10:09 PM
Car: 1989 IROC
Engine: LB9
Well, I suppose a full explanation is in line.
We are on the road a few days back, and he's taking off from a red light. The car hesitates like something is stuck, and then you hear this terrible crunching noise from the rear passenger drum. The rest of the day you can hear whatever was left of the shoes kinda bouncing around in the drum. It still will work to stop the car, it just MOANS really loud from that side, and now the front driver side disc brake starts to act up after 10 minutes or so of driving (especially when heavy breaking is involved). I can't do drum brakes, and niether can he, so he got some estimates on repair, he's just bugging me to find out if he should replace the whole system, or just this drum. Not to worry, he's not driving it for now.
He's got a big budget for 383/TH-350 and whatnot, and is planning on ditching the stock rear axle and drum brakes for a 4th gen rear end anyways, and is only looking for something to temporarily hold up for 3-4 months or so.
Old Jan 5, 2006 | 11:59 AM
Bens3rdGen's Avatar
Car: 91 Camaro RS
Drum brakes are much more complicated then disks. I wouldn't try to work on them without a service manual.
More than likely you got a defective shoe and the brake material came off the shoe. It depends on where the material came off, but it sounds like you will probably have to replace the the pass side drum. In addition I would get a new set of shoes and have the driver's side drum turned. Finally I would check the condition of your brake fluid, if it is very dark and smells burned it will not be able to handle very much heat and can cause your brake to bind. Brakes are pretty important and I've seen 3-4 months turn into a year many times. Good luck.
Ben
Old Jan 5, 2006 | 04:48 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Just FYI, contaminated brake fluid will do a number on all the rubber seals in the entire system if given enough time. If the fluid looks like crap and leaves a dark residue on the MC reservoir, that is likely a contributing factor, if not the entire source of the failures.
Unfortunately, the only way to really fix things once you get to that point is to replace EVERY rubber part in the system -- i.e. rebuild the calipers, master & rear cylinders, along with a complete fluid flush.
IMHO, the best solution is to prevent it from happening in the first place, by flushing the brake fluid on a regular basis.
Old Jan 8, 2006 | 08:21 PM
MurcoRS's Avatar
Car: 1989 Camaro RS
Engine: ZZ4 350
Axle/Gears: BW 9-bolt w/3.73
Instead of guessing about what has broken inside the drum why hasn't he actually removed the drum and see what has broken?
Old Jan 10, 2006 | 03:31 PM
Bens3rdGen's Avatar
Car: 91 Camaro RS
He said he didn't feel comfortable taking it apart.
Maybe he doesn't know what a bad drum looks like? Or maybe he doesn't know what the parts are called? I have no idea what he knows.
I just figured I'd give him some basic info, with my description he could talk to a shop and know if he was getting ripped off or not.
I'm sure he'll ask a couple more q's. just tryin to give him a place to start.
1992 Trans Am
May 10, 2023 07:19 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
AkDrifted
Aug 17, 2015 07:45 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
