Brake uprades
Old Jan 26, 2006 | 03:07 PM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
Brake uprades
are there any brake upgrades that will fit under the stock 15" Z-28/RS wheels? if not are there aftermarket rims that are larger but have the same look?
Old Jan 26, 2006 | 04:31 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
The C4 brake upgrade (12") would be a good choice to fit under those wheels. Otherwise, you're going to have to large at larger wheels.
https://www.thirdgen.org/techbb2/sho...hreadid=142115
Old Jan 26, 2006 | 05:22 PM
xplane's Avatar
Engine: 2.8 MFI
well dang i was lookin for a bolton kit. is there anywhere that makes larger rims in the same look as the Z-28/RS rims? those are my favs on camaros so id like to keep the look.
Old Jan 26, 2006 | 05:34 PM
Nate86's Avatar
Engine: 4 cylinder
Ed Miller makes a C4 kit that you can purchase directly from him. It has everything you need for the upgrade. I am going to do that once I get some extra money to play with for brakes.
Honestly, I would stay away from any aftermarket kits offered by Baer and others... more often than not, they are GM parts that are rebadged with the company's logo on them, but with a price tag that's double of the regular GM parts.
Old Jan 26, 2006 | 05:38 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
A 12" 1LE system should fit as well. Both the C4 and 1LEs can be had in bolt on kits. PM me if you need more info on them.
As far as larger stock looking wheels, check the appearance forum. Some guys over there have stock looking wheels in 18" IIRC.
Ed
Old Jan 26, 2006 | 06:31 PM
xplane's Avatar
Engine: 2.8 MFI
I found larger Iroc wheels in 18" and 20"
BADNBLK
Convertibles
Sep 21, 2015 07:56 PM
dbrochard
Sep 19, 2015 08:13 PM
Necron
Brakes
Sep 14, 2015 12:45 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
