brake hose problem..WTF?????
Car: 1991 firebird
Engine: 305 TBI
Transmission: 5spd
so my brake are not working on the front passenger side. i changed the pads and the caliper but it appears that little to no fluid is coming out of the brake line. i disconnected the hose from the caliper and tried to find out what was going on but i have no clue, when i pump the brakes harly any fluid comes out. could it just be a problem with the rubber brake line that connects to the caliper or something worse?
thanks
thanks
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Brake lines corrode from the inside, replace the lines on both sides. If one is bad, you can bet the other one is too.
Ed
PS: https://www.thirdgen.org/techbb2/sho...hreadid=207360
Ed
dbrochard
Sep 19, 2015 08:13 PM
